PROBLEM
When upgrading ArcGIS Enterprise environments that contain ArcGIS Server federated with Portal for ArcGIS, a known issue occurs with three different ArcGIS Server Utility services. These services were introduced into ArcGIS Server at various releases between 10.5 and 10.6.1. These Utility services are:
When performing workflows in the Enterprise portal which leverage these Utility services, the following error is returned:
“Unable to access the utility service.”
If using a web debugger to inspect the network traffic to the Utility service, the following error is returned:
“{"error":{"code":403,"subcode":2,"message":"User does not have permissions to access 'utilities/<UTILITY SERVICE NAME>.gpserver'.","details":[]}}”
This issue occurs when upgrading to versions where these utility services are found, which are 10.5, 10.5.1, 10.6, or 10.6.1.
When ArcGIS Enterprise is upgraded to one of these affected versions, the OfflinePackaging, RasterUtilities, and GeocodingTools Utility Services on ArcGIS Server are no longer available to their federated Portal for ArcGIS, as their sharing properties are incorrectly set. To resolve this, the Utility services must have their sharing properties updated, so that the Enterprise portal can once again leverage this functionality.
To resolve this issue, do the following steps after upgrading your ArcGIS Enterprise:
Since ArcGIS Server is federated with Portal for ArcGIS, the updated sharing properties for these utility services propagates to the federated Enterprise portal. Once these services have been shared, they function as expected.
Article ID: 000018880
Get help from ArcGIS experts
Start chatting now
