PROBLEM
Running the Add Join tool using a one-to-many join operation in ArcGIS Pro 3.5 returns only partial records in the attribute table. In this example, only two out of four records are returned, as shown in the image below.
The input datasets are not stored in the same file geodatabase. In ArcGIS Pro 3.4 and earlier, a one-to-many join works as expected when both datasets have an ObjectID field. However, starting with ArcGIS Pro 3.5, both datasets must be stored in the same file geodatabase to support a one-to-many join. If they are in different locations, the tool defaults to a one-to-first join, returning only partial records.
To resolve the issue, apply the following steps to add the input and join tables to the same file geodatabase.
The image below shows the complete records of the one-to-many join in the attribute table.
Note: Alternatively, use the Join Field tool to add the joined attributes directly into the input dataset in ArcGIS Pro. Refer to ArcGIS Pro: Join Field (Data Management) for more information.
Note: The Join Field tool creates a permanent join by adding the joined attributes directly into the input dataset, whereas the Add Join tool creates a temporary join that can be removed without altering the original data.
Article ID: 000038521
Get help from ArcGIS experts
Start chatting now
