PROBLEM
Accessing a service increases ArcGIS CPU usage to 100%
First Published: July 7, 2021
Last Published: August 30, 2021
When attempting to access a service in ArcGIS Server, the operation may fail. ArcGIS Server CPU usage increases to 100%, and the ArcGIS Server machine may fail intermittently. The log files display the following error messages:
Error:
32905 - <Msg time="date_time" type="INFO" code="9029" source="Rest" process="20788" thread="1" methodName="" machine="machine_name" user="" elapsed="" requestID="request_ID">Request user: username, Service: Hosted/service_name/FeatureServer</Msg>
32954 - <Msg time="date_time" type="WARNING" code="9003" source="Rest" process="20788" thread="1" methodName="" machine="machine_name" user="" elapsed="" requestID="request_ID">Unable to process request. Java heap space</Msg>
The error message preceding the Java heap space error notifies the user which service is causing the performance issue in ArcGIS Server.
Cause
The Java heap size for the service is not large enough. The heap size setting controls the maximum file size a client can provide, and a service with a small heap size may not be able to handle large requests, causing performance issues within ArcGIS Server.
Solution or Workaround
  1. Republish the affected service to ArcGIS Server. For more information on publishing services, refer to ArcGIS Server: Approaches to publishing services.
  2. Increase the Java heap size for the republished service. For steps, refer to ArcGIS Server: Heap size.
  3. Increase the upload size setting to allow large uploads for the service. For steps, refer to ArcGIS Server: Upload size.
Article ID: 000026012
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
