PROBLEM
The ProjectZ tool is designed to transform the collected GPS latitude, longitude, and altitude values into 3D points as well as convert altitude (height above ellipsoid) values into elevation values. When transforming the vertical datum, the following error message is returned:
WARNING: 0001837: Cannot validate datum transformation.
Install ArcGIS Coordinate Systems Data for ArcGIS Pro
Article ID: 000026751
Get help from ArcGIS experts
Start chatting now
