PROBLEM
10.1 clients cannot connect to the License Manager
10.1 clients cannot connect to the License Manager but 10.2 clients can.
Cause
If the client is set for IPv6 only, ArcGIS Administrator 10.1 cannot find the License Manager.
To determine if IPv6 is the cause, perform the following steps.
1. Open a command prompt window.
2. At the command prompt type:
tracert <LM_Server_Name>
3. Press Enter.
This should return the path to the License Manager along with the IPv4 address. If it returns the IPv6 address only, go to the site below and run the Microsoft utility to set the IPv4 over IPv6.
Solution or Workaround
Set the client machine for IPv4 over IPv6 per Microsoft KB 929852:
How to disable IP version 6 or its specific components in Windows
    Article ID: 000011909
    Software:
    • ArcMap
    • ArcGIS Data Reviewer
    • ArcGIS Workflow Manager
    Download the Esri Support App
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Go to download options
