PROBLEM
Printer properties button in ArcMap is grayed out
First Published: May 5, 2016
The Printer Properties button on the ArcMap Page and Print Setup dialog box is grayed out and changes cannot be made although ArcMap can print to the printer.
Cause
This may occur if the printer was installed using a 'rundll32' command.
Two fabricated examples of this command are:
Code:
rundll32 printui.dll, PrintUIEntry /ga /n \printerserver\printer
or
Code:
rundll32 printui.dll,PrintUIEntry /ga /c\\%COMPUTERNAME% /n\\printerserver\printer
Solution or Workaround
Add the printer programmatically using a Windows Script Host .VBS script.
  • Use the following code saved in a .VBS file to add a printer when called from the command line:
    Code:
    'AddPrinters.vbs
    'start
    Set WshNetwork = WScript.CreateObject("WScript.Network")
    WshNetwork.AddWindowsPrinterConnection "\\<printerserver>\<printer>"
    'end
Article ID: 000008139
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
