DEPRECATION
Pre-built AMIs in AWS Marketplace
Last Published: January 14, 2025
For many releases, Esri has provided pre-built Amazon Machine Images (AMIs) for customers running ArcGIS Enterprise on Amazon Web Services (AWS). ArcGIS Enterprise 10.9.1 will be the last release for which pre-built AMIs will be available in the AWS Marketplace.
These AMI's follow ESRI's product life cycle and once a version has reached mature support ESRI is no longer required to patch the AMIs. Please reference the following: ArcGIS Enterprise Life Cycle | Esri Support
This deprecation only affects AMIs in the AWS Marketplace and does not impact the continued availability of similar machine images in the Microsoft Azure Marketplace.
Recommendation
Customers that make use of the pre-built AMIs listed in the AWS Marketplace have a number of alternatives. Beginning with ArcGIS Enterprise 10.9.1, a new Image Builder CloudFormation template will be available to generate an AMI using your own AWS account. It is also possible to manually create an AMI by installing the individual ArcGIS Enterprise software components on a compatible base AMI of your choice.
Article ID: 000026345
Software:
  • ArcGIS Data Store
  • Portal for ArcGIS
  • ArcGIS Server
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
