PROBLEM
Portal for ArcGIS and ArcGIS Server URL is not working
Last Published: August 11, 2025
When attempting to load the Portal for ArcGIS and ArcGIS Server URL it is not working, and returns a connectivity issue, "...can't reach this page...refused to connect."
Cause
This may be due to a Windows service-related issue. Sometimes, the service becomes locked and is unable to stop or restart. When attempting to stop the service, Windows may display the following error:
'Error 1053: The service did not respond to the start or control request in a timely fashion.'
Error 1053 message
Solution or Workaround
  1. Open Task Manager and select the Services tab. Note the PID of the following Windows services:
    • Portal for ArcGIS
    • ArcGIS Server
    • ArcGIS Data Store.
task manager services tab
  1. Open the Command Prompt, Run as administrator.
  2. Stop the service from the command line with the PID using the command:
taskkill /f /pid <ProcessID>
  1. For <ProcessID> use the PID for the service noted in step 1.
  2. Perform this step for Portal for ArcGIS, ArcGIS Server, and ArcGIS Data Store.
  3. Exit the Command Prompt.
  4. Start the services for Portal for ArcGIS, ArcGIS Server, and ArcGIS Data Store from the Windows Services console.
Article ID: 000035579
Software:
  • ArcGIS Data Store
  • Portal for ArcGIS
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
