PROBLEM
Portal for ArcGIS 10.5.1 becomes unresponsive after uninstalling a patch or hotfix
First Published: August 10, 2018
Last Published: January 9, 2026
When uninstalling any Portal for ArcGIS 10.5.1 patch or hotfix that contains the fix for BUG-000114488, Portal for ArcGIS becomes unresponsive and accessing the Portal website displays a blank page in the web browser.
Applicable software patches include:
Cause
Additional configuration changes are required after the software changes for BUG-000114488 are uninstalled.
Solution or Workaround
After running the Windows patch uninstaller, download and run Uninstall_BUG-000114488.bat by following the instructions below.
  1. Download the .zip archive, Uninstall_BUG-000114488.zip.
  2. Extract the contents of the .zip archive to a folder on the machine hosting Portal for ArcGIS.
  3. Open a new Command Prompt and navigate to the location of the extracted .zip archive (from Step 2.)
  4. Run the command Uninstall_BUG-000114488.bat.
  5. Restart the Windows service for Portal for ArcGIS.
Article ID: 000018865
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
