HOW TO
Points of interest location search suggestions in ArcGIS Business Analyst Web App
First Published: February 25, 2026
Last Published: June 26, 2026
Summary
Location search in ArcGIS Business Analyst Web App has been redesigned in the February 2026 release. It has been improved to provide faster and more intuitive results. You will see this updated design in the following places:
Procedure
In the updated search bar, you can enter your search terms, use your current locations, or select a recently searched location. If you enter search terms, filter the results by addresses, geographies, or points of interest.
  • Addresses include results for locations based on the name and number of a street or coordinates.
  • Geographies include results for locations based on standard geographies, such as ZIP codes or counties.
  • Points of interest include results for locations based on the name of the business.
Filtered location search suggestions by points of interest
If you search for points of interest locations, your results may differ from what you expect. Unlike the points of interest (POI) search workflow that uses data sources like Data Axle, SafeGraph, and Foursquare, the location search for points of interest uses TomTom as a source for its suggestions.
You may be familiar with TomTom as an Esri partner since they are credited in most basemaps. TomTom provides location data and services, such as geographic boundaries and locations of businesses. It does not replace the points of interest (POI) data sources.
Basemap data accreditation
Additionally, this redesigned search behavior differs from previous releases, where you could use the Search map tool drop-down menu to launch a points of interest (POI) search workflow.
Launch a points of interest (POI) search workflow from the Search map tool
In order to launch a points of interest (POI) search workflow in the redesigned location search, enter your search terms and filter by Points of interest. The first result uses a different icon and includes a subtitle: Points of interest - keyword search. Click this result to launch the points of interest (POI) search workflow with the search terms applied to a keyword search.
Launch points of interest (POI) search workflow from the filtered Points of interest search suggestions
Article ID: 000040310
Software:
  • ArcGIS Business Analyst Web App
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
