Summary
Steps to place shadow boxes behind layout frames.
Procedure
- Open the layout.
- Select the Draw Rectangle tool.
- Draw a rectangle around the desired layout frame.
- Set the rectangle fill to a solid fill.
A. Select the graphic.
B. Click Show Symbol Window under the Graphics menu.
C. Click the fill palette icon.
D. Click a fill style.
![[O-Image] Change fill style of a graphic](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000004047/00N39000003LL2C-0EM39000000wcad.png)
- Set the color of the fill to white.
C. Set Color to Foreground.
D. Click a color.
![[O-Image] Change fill color of a graphic](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000004047/00N39000003LL2C-0EM39000000wcaM.png)
- Select the Send to Back option from the Graphics menu.
- Draw a rectangle in an offset position from the white rectangle.
- Set the rectangle fill to a solid fill, as you did before.
- Set the color of the fill to black, just as you did for the white rectangle.
- Select the Frame, the white rectangle, and the black rectangle, by holding down the shift key and clicking them.
- Select the Group option from the Graphics menu.
