PROBLEM
Park name is listed as 'undefined' on the search results in the Park and Recreation Finder
First Published: May 5, 2016
In the Park Finder application, when searching for a park by address, name, or activity, the park names are listed as 'undefined' in the results column.
ArcGIS for Local Government provides maps and apps that help implement GIS in a local government context, and a destination where users, partners, and the teams within Esri can collaborate.
Cause
The alias listed in the application's configuration file for the park name field does not match the park search service's definition.
Solution or Workaround
  1. Navigate to <installation folder> and open the config.txt file for editing.
  2. In the config.txt file, find the URL of the service specified for the 'DevPlanLayer'.
    For example, this might be similar to the following:
    https://localgovtemplates2.esri.com/ArcGIS/rest/services/Planning/Parks/MapServer/0
  3. In a web browser, go to the DevPlanLayer URL. In the Fields list, find the field that represents the 'undefined' facility in the search results list.
    For example, this might be NAME, or FacilitySitePoint.NAME, or some other field.
  4. Make note of the field's Alias text.
    For example, you might see:
    FacilitySitePoint.NAME (Type: esriFieldTypeString, Alias: Park Name, Length: 255)
    or
    FacilitySitePoint.NAME (Type: esriFieldTypeString, Alias: Name of Facility, Length: 255)
    or
    FacilitySitePoint.NAME (Type: esriFieldTypeString, Alias: Facility Name, Length: 255)
  5. Back in the config.txt file, find the configuration item called 'InfoWindowHeader'.
    Code:
    'InfoWindowHeader' : [
    {"FieldName":"FacilitySitePoint.NAME","Alias":"Park Name"}
  6. Set the value associated with the FieldName tag to the name of the field chosen in Step 3, and set the value associated with the Alias tag, identified in Step 4, to the Alias text for that field.
    For example, if the following field was selected from a service,
    FacilityName (Type: esriFieldTypeString, Alias: Name of Facility, Length: 255)
    the InfoWindowHeader would be changed to the following to use that field.
    Code:
    {"FieldName":"FacilityName","Alias":"Name of Facility"}
  7. Save the config.txt file.
Article ID: 000011571
Software:
  • ArcGIS for Local Government
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
