BUG
Parallel Processing does not work in ArcMap with 64-bit Background Geoprocessing enabled.
This is a known limitation/as designed behavior, and has been reported as the following defect:
NIM087308 Parallel Processing does not work with 64-bit Background Geoprocessing at ArcMap (ArcGIS for Desktop)
Parallel processing is not supported in 64-bit Background Geoprocessing. Users can either run tools that support parallel processing with 32-bit Background Processing set up in ArcMap or migrate to ArcGIS Pro.
To make sure that parallel processing works in ArcMap (ArcGIS Desktop), follow these steps:
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000020455/00N39000003LL2C-0EM39000000wdX1.png)
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000020455/00N39000003LL2C-0EM39000000wdXD.png)
Article ID: 000020455
Get help from ArcGIS experts
Start chatting now
