ERROR
Access denied. Output directory is inaccessible, requests with return type as URL fail
Last Published: April 29, 2024
Error Message
When attempting to export map services, the following error is returned:
Error:
 Access denied. Output directory is inaccessible, requests with return type as URL fail.
Error
Cause
This issue may occur when the arcgisoutput directory parameter is incorrectly configured. The arcgisoutput folder is a necessary component in the ArcGIS Server site.
Solution or Workaround
To resolve this issue, edit the service properties in ArcGIS Server Manager. Follow the instructions provided below:
  1. Log in to ArcGIS Server Manager.
  2. In the Services page, click the desired service.
  3. Navigate to Parameters.
  4. Under the Specify Output Directory section, set the Output Directory to the default directory. Ensure it matches the site output directory. For example, if the site was installed by default in C:\arcgisserver, the output directory would be C:\arcgisserver\directories\arcgisoutput.
serviceparameter
  1. Click Save and Restart. The edit service is applied.
Article ID: 000018020
Software:
  • ArcGIS Server
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
