PROBLEM
Random Oracle ORA-00600 errors can occur when working with ArcGIS and Oracle 10g if a table or index has a degree of parallelism greater than one.
If ArcGIS is encountering an Oracle ORA-00600 error, the first step is to inspect the Oracle alert log for the error. The Oracle alert log contains the error number and the path to the file name that contains additional information from the session that encountered the error. The following text was extracted from an Oracle alert log that contains the Oracle ORA-00600 error and the file from the session with additional information.
Code:
Mon Aug 25 09:23:35 2008
Errors in file /app/oracle/admin/geodb/bdump/geodb_p000_17415.trc:
ORA-00600: internal error code, arguments: [kxspoac : EXL 1], [23], [23], [], [], [], [], []
Code:
ksedmp: internal or fatal error
Current SQL statement for this session:
SELECT COUNT(OID) FROM (SELECT b.OID,b.PAGENUMBER FROM
joe_l.N_2_EStatus b WHERE b.OID NOT IN (SELECT /*+ HASH_AJ */
SDE_DELETES_ROW_ID FROM joe_l.D309 WHERE DELETED_AT IN (SELECT l.lineage_id FROM
SDE.state_lineages l WHERE l.lineage_name = :source_lineage_name
AND l.lineage_id <= :source_state_id) AND SDE_STATE_ID = 0) UNION ALL SELECT a.OID,a.PAGENUMBER FROM joe_l.A309
a,SDE.state_lineages SL WHERE (a.OID, a.SDE_STATE_ID) NOT IN (SELECT /*+ HASH_AJ */
SDE_DELETES_ROW_ID,SDE_STATE_ID FROM joe_l.D309 WHERE DELETED_AT IN (SELECT
l.lineage_id FROM SDE.state_lineages l WHERE l.lineage_name
= :source_lineage_name AND l.lineage_id <= :source_state_id) AND SDE_STATE_ID >
0) AND a.SDE_STATE_ID = SL.lineage_id AND SL.lineage_name = :source_lineage_name AND SL.lineage_id
<= :source_state_id ) V__309
----- Call Stack Trace -----
The cause of the problem is Oracle Bug 5045992 - OERI[kxspoac : EXL 1] from PQ with a numeric bind.
Additional information on this issue can be found by using Oracle's MetaLink and searching for article 458111.1.
Code:
SQL> DECLARE
2 CURSOR mycur IS SELECT table_name FROM user_tables
3 WHERE degree NOT IN ('0','1');
4 BEGIN
5 FOR mylp IN mycur LOOP
6 EXECUTE IMMEDIATE 'ALTER TABLE '||mylp.table_name||' PARALLEL 1';
7 END LOOP;
8 END;
9 /
PL/SQL procedure successfully completed.
SQL> DECLARE
2 CURSOR mycur IS SELECT index_name FROM user_indexes
4 BEGIN
6 EXECUTE IMMEDIATE 'ALTER INDEX '||mylp.index_name||' PARALLEL 1';
7 END LOOP;
8 END;
9 /
Article ID:000010252
Get help from ArcGIS experts
Download the Esri Support App
