ERROR
When attempting to create a spatial index on a st_geometry attribute with SQL, the command fails with the following Oracle error:
"ORA-29855 error occurred in the execution of ODCIINDEXCREATE routine".
In this specific case, the Oracle error ORA-29855 is being encountered because the parameters string clause contains an unnecessary comma between the st_srid and st_grids parameters.
Code:
SQL> CREATE INDEX shp_idx_1k ON st_relation_perf (shape) INDEXTYPE IS sde.st_spatial_index
2 parameters('st_srid=12, st_grids=25000');
ERROR at line 1:
ORA-29855: error occurred in the execution of ODCIINDEXCREATE routine
ORA-06502: PL/SQL: numeric or value error: character to number conversion error
ORA-06512: at "SDE.SPX_UTIL", line 190
ORA-06512: at "SDE.SPX_UTIL", line 696
ORA-06512: at "SDE.ST_DOMAIN_METHODS", line 1438
Code:
2 parameters('st_srid=12 st_grids=25000');
Article ID:000010701
Get help from ArcGIS experts
Download the Esri Support App
