ERROR
ORA-01400: cannot insert into" table when loading into Oracle
First Published: May 5, 2016
Error Message
While copying, pasting or loading a feature class or table from a non-Oracle geodatabase into Oracle, the following error is returned:
"Underlying RDBMS error [ORA-01400: cannot insert into ("TB","MYTABLE","MYFIELD")]"
Cause
This error can occur when there are zero-length ('') strings in a table field. These are valid in a file geodatabase, personal geodatabase and most supported RDBMS, such as SQL Server, Informix, DB2, and PostgreSQL, but are interpreted as NULLs in Oracle. When using copy/paste or any data-loading tool, records containing '' (zero-length) strings are rejected if the field is flagged to not allow NULLs.
Solution or Workaround
Replace all occurrences of zero-length strings in the text fields with ' ' (a quoted blank space).
Use the following WHERE clauses to select the zero-length strings and then update the field values to a quoted single space (' ').
File Geodatabase:
CHAR_LENGTH(myfield) = 0
Personal Geodatabase:
LEN(myfield) = 0
SQL Server:
DATALENGTH(myfield) = 0
DB2:
LENGTH(myfield) = 0
Informix:
PostgreSQL:
    Article ID: 000011559
    Software:
    • ArcGIS Server
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
