ERROR
When ArcCatalog is used to register a feature class as versioned, the following error code is returned:
"ORA-00920 invalid relational operator"
The Oracle parameter STAR_TRANSFORMATION_ENABLED is set to TRUE.
The Oracle parameter is set to TRUE by default when installing an Oracle database using the Data Warehouse template.
Refer to Oracle documentation on how to set parameters for the database.
Article ID:000006469
Get help from ArcGIS experts
Download the Esri Support App
