HOW TO
Optimize a slow library
Summary
This article offers some tips for optimizing the drawing speed, querying speed, and overall performance of large Map Librarian and ArcStorm date sets.
Procedure
  • Use appropriate scale data for the task at hand.
  • Use theme properties to control when a theme draws based on scale.
  • Build spatial indexes for your data.
  • In ArcInfo, build spatial indexes for all tiles and layers on a tile by tile basis (Use the VISIT command in Librarian).
  • Build spatial indexes for all shapefiles in Arcview.
  • Remove unused data, such as unused fields, from all source data sets.
  • In ArcView, use the 'Area of Interest' tool to limit the number of tiles that are active at one time.
  • If you need to display and process more than 10 tiles, convert them to a shapefile, then store it and process it locally.
  • Store the static data locally and reference the dynamic data across the network.
  • Don't use theme definitions; instead, build specific data sets containing only the needed data.
  • Build Arcview index fields for the fields used for queries and for the fields used for classifying themes.
  • Don't use global joins and links; instead, build a shapefile with only the needed records and join or link to that shapefile with your additional data.
  • Don't use wild cards in queries, as they don't use attribute indexes; instead, use exact matching queries that use the equals function.
  • If you have any queries that use 'And' or 'Or', simplify them and add them to the simplified queries. Attribute indexing only works for simple queries.
Article ID:000003897
Software:
  • Legacy Products
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
