ERROR
Operation Failed [using Density function]
Error Message
The Spatial Analyst Density function returns the following message:
"Operation Failed"
Cause
The input dataset may contain a Null or Empty geometry. That is, there is a record without a corresponding feature.
Solution or Workaround
Selecting the features that can be seen in the Data View of ArcMap will allow the Density function to use only those records with a physical feature.
  1. Use the Select Features tool to select all the input features seen in the Data View.
  2. Run the Spatial Analyst > Density function.
Article ID:000005407
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
