ERROR
After adding a shapefile into ArcMap, the following message appears and the layer does not draw:
"Error opening feature class. General function failure"
AppLockMgr.exe is not registered. ArcMap and ArcCatalog need this helper application for working with shapefiles.
Register AppLockMgr.exe.
Warning: The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary. Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
cd c:\arcgis\arcexe81\bin
Note: In the case of ArcGIS 9, the bin folder is located under C:\Program Files\ArcGIS, so the syntax would be as follows:
cd c:\Progra~1\ArcGIS\Bin
Article ID:000005097
Get help from ArcGIS experts
Download the Esri Support App
