ERROR
Invoking a Set prompt interaction on a map-enabled report sometimes returns the following error:
"OP-ERR-0217 An unexpected type of parameter value was encountered. The specified parameter type is 'String', but the expected type is 'memberUniqueName'."![[O-Image] Error message](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012560/00N39000003LL24-0EM39000000wdgA.png)
This error occurs in map-enabled reports configured with a Set prompt interaction in Esri Maps Designer when the report contains data from a Power Cube (OLAP) data source. In Report Studio, to satisfy a filter expression in a query based on Power Cube (OLAP) data, the filter expression expects a memberUniqueName (MUN) value to be returned. However, when the Set prompt interaction is configured and invoked in Esri Maps for IBM Cognos, a string value for the item is passed instead of a MUN value so the filter expression can’t be satisfied.
Code:
caption(<Country>) = ?countryPrompt?
Article ID: 000012560
Get help from ArcGIS experts
Start chatting now
