ERROR
One or more of selected objects could not be deleted
Last Published: May 3, 2021
Error Message
This article pertains to ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
When a geometric network and any or all of the feature classes participating in the network are selected and deleted within ArcCatalog, as a result, the geometric network and disconnected junction feature class are deleted, and the following error is returned:
Error:
After the error, none of the remaining feature classes can be deleted.
Solution or Workaround
Refresh the dataset by either pressing the F5 key, or by right-clicking the Feature Dataset and selecting the Refresh command. The remaining feature classes can then be deleted.
Article ID: 000003258
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
