ERROR
Note: The content in this article pertains to ArcGIS versions 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
When publishing a map document that contains maplex labeling, the following error message occurs:
"One or more layers in the map do not support publishing. These layers were removed from the published map. Use the Map Summary dialog to determine which layers do not support publishing."
ArcReader Publisher does not support Maplex labeling. When viewed in ArcReader, Publisher does not have the Maplex extension available and cannot label the features.
Turn off Maplex before publishing the map.
Article ID:000008643
Get help from ArcGIS experts
Download the Esri Support App
