PROBLEM
Nothing happens when clicking the Edit metadata button in ArcCatalog
The Metadata Editor doesn't appear when clicking the Edit Metadata button in ArcCatalog.
Cause
This is a known issue.
Solution or Workaround
The following is a potential solution:
  1. In Arc Catalog select Tools > Options and select the Metadata tab.
  2. Uncheck the following check boxes:
    - Automatically create metadata the first time an item in the Catalog is viewed in the Metadata tab
    - Automatically update metadata whenever an item's metadata is viewed in the Metadata tab
  3. Re-check both check boxes.
  4. Click Apply and OK.
Article ID: 000004050
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
