ERROR
Not able to validate metadata using ISO 19139 Metadata Implementation Specification
Error Message
When trying to validate metadata using the ISO 19139 Metadata Implementation Specification metadata style, the user receives the following error:
 "The remote server returned an error: (404) Not Found. Failed to execute (Validate Exported Metadata)."
Cause
The Schema Url: "https://www.isotc211.org/schemas/2005/gmd/metadataEntity.xsd" does not exist.
Solution or Workaround
When running the Validate Metadata tool, change the parameter Schema Url from:
to:
https://www.isotc211.org/2005/gmd/metadataEntity.xsd
To change the default parameter of this tool, so that it is not necessary to change it manually each time one wants to validate a metadata, modify the CFG file of the metadata style. This is located in the following path:
C:\Program Files (x86)\ArcGIS\<ArcGIS Version>\Metadata\Config\ISO 19139 Metadata Implementation Specification
To modify this file, run Notepad as an administrator and open it. Change the line:
<validationSchemaURL>https://www.isotc211.org/schemas/2005/gmd/metadataEntity.xsd</validationSchemaURL>
to:
<validationSchemaURL>https://www.isotc211.org/2005/gmd/metadataEntity.xsd</validationSchemaURL>
This sets the default parameter with the correct URL.
Article ID: 000023569
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
