PROBLEM
Geodatabase feature classes or tables containing long integer type fields named OID or ROWID cannot be deleted.
Data exported from a joined feature class or table to a geodatabase may appear to contain more than one ObjectID field. One field will have a field type of ObjectID and the other, usually named OID or ROWID, will have a type of long integer.
The REQUIRED property is set for the exported long integer OID fields. Since required fields can't be deleted, it is not possible to delete these fields.
Right-click on the table or layer in ArcMap table of contents > properties.
Under the Fields tab > click on the ObjectID or ROWID field > uncheck the visible box
> click OK.
Article ID:000004368
Get help from ArcGIS experts
Download the Esri Support App
