PROBLEM
No tools will appear under the System Toolboxes in ArcToolbox
First Published: May 5, 2016
When viewing the ArcToolbox in ArcCatalog or ArcMap, only the top level of toolboxes, such as Cartography, Data Management, and Conversion tools are visible.
Cause
The ArcToolbox Template has become corrupt.
Solution or Workaround
Find and rename the Arctoolbox.dat file.
  1. Navigate to C:\Documents and Settings\<login>\Application Data\ESRI\ArcToolbox
  2. Rename arctoolbox.dat to arctoolbox_old.dat
  3. Close all ArcGIS applications and then open ArcCatalog again.
    The tools should now be visible.
Article ID: 000007312
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
