PROBLEM
When adding a locator as a Utility Service in ArcGIS Online or ArcGIS Enterprise, the “Select Existing Locator” option may not be available:
This behavior occurs when:
If the locator is not available as a portal item or is not visible to the organization, there will be no option to “Select Existing Locator”.
If the locator has not yet been added to the portal, create a new item using its REST URL.
https://webadaptor.domain.com/arcgis/rest/services/folder/servicename/GeocodeServer
Once added and shared properly, the locator becomes available as a selectable item.
After confirming that a locator item exists and is shared correctly:
Article ID: 000042268
Get help from ArcGIS experts
Start chatting now
