PROBLEM
No log file is created for the Repair Connectivity command in the registry setting
After creating a string registry in HKEY_CURRENT_USER\Software\ESRI\Geodatabase and running the Repair Connectivity command, the log file is not created.
Cause
Desktop Help incorrectly names the registry setting as 'RepaireConnectivity'.
Solution or Workaround
Change the name of the string registry setting to 'RepairConnectivity'.
Warning:
WARNING: This article contains instructions to make specific changes to essential parts of your operating system. If these specific changes are not done correctly, it may cause serious problems to your computer operating system and files. First, ESRI recommends that you make a complete backup of your system, including the registry, before implementing any of the specific changes. It is highly recommended that you consult with your IT/MIS department, or other qualified computer systems professional before proceeding. ESRI cannot guarantee that you can solve problems that result from incorrect use of the Registry Editor utility. Use the Registry Editor utility at your own risk. Note: your operating system and any subsequent service packs may effect these instructions. These instructions are subject to change without notice.
    Article ID: 000005991
    Software:
    • ArcMap 8 x
    • ArcMap 9 x
    Download the Esri Support App
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Go to download options
