BUG
NIM082086: The Check Parcel Fabric option is disabled in stand-alone ArcCatalog
When using the Parcel Fabric context (pop-up) menu in ArcCatalog, the Check Parcel Fabric option is disabled.
[O]
Cause
This is a software defect; the following workarounds are provided:
Workaround
Use the Catalog window in ArcMap:
1. Open ArcMap and click Catalog to open the ArcCatalog window.
2. Right-click a parcel fabric and click the Check Parcel Fabric option.
Add the tool to ArcMap:
1. In ArcMap, go to Customize > Customize mode, click the Commands tab and type Check Parcel Fabric.
2. Add the Check Parcel Fabric tool to any toolbar.
3. Start an edit session, select the parcels to check, then click the tool.
    Article ID: 000011857
    Software:
    • ArcMap
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
