PROBLEM
Network dataset is empty after it is copied from one geodatabase to another
First Published: May 5, 2016
After copying a network dataset from one geodatabase to another, previewing the copied network dataset in ArcCatalog shows an empty display. The original network dataset, however, shows its network elements when previewed in ArcCatalog.
Cause
When a network dataset is copied from one geodatabase to another, only the schema information of the network dataset is copied. The network elements are not copied.
Solution or Workaround
In ArcCatalog, right-click the copied network dataset and click Build. This will create the network elements in the copied network dataset.
Article ID: 000007813
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
