ERROR
Navigating to an input raster in the Reclassify dialog box of the Spatial Analyst causes a fatal error.
If a colormap is associated with the input raster dataset, and the default field is a string, navigating to such a dataset in the Reclassify dialog will cause a fatal error in ArcGIS 8.1.
For previous versions, add the raster dataset as a layer to ArcMap before opening the Reclassify dialog box. Then, use the layer as the input raster for the Reclassify function.
Article ID:000004515
Get help from ArcGIS experts
Download the Esri Support App
