PROBLEM
Multipatches and extruded polygons do not display as expected in ArcGIS Pro
First Published: May 5, 2016
When multipatches or extruded polygons are added to a local or global scene in ArcGIS Pro, the polygons are missing or sections of the polygons do not display as expected.
[O-Image]
Cause
3D data in ArcGIS Pro uses elevation surfaces to determine the height of layers in the scene. By default, a ground surface called 'ground' is added to every new scene. Both local and global scenes use elevation surfaces, and when layers are added to a scene, the layers may be displayed underneath the elevation surface. This may happen if the layer's elevation is set to an absolute height based on the feature's z-values. To see the data, display structures on top of the ground by using the ground elevation as the layer's base elevation.
Solution or Workaround
Change the layer's properties to display features on the ground.
  1. In the Table of Contents, right-click the layer.
  2. Click Properties.
  3. Select Elevation.
  4. In the 'Features are:' drop-down box, select 'On the ground'.
    [O-Image]
  5. Click Ok. The features display as expected.
    [O-Image]
Article ID: 000012267
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
