ERROR
MSEEK no space left on device
Error Message
When starting editing on a shapefile, the following error occurs:
Error:
Cause
ArcView is attempting to write to a directory that is full.
Solution or Workaround
  1. Check to see if there is available space on the hard disk. To do so, open up a UNIX prompt, and type in the command, df -k. This returns the total and available disk space in kilobytes (KB).
  2. If the Working Directory in Project Properties is set to $HOME, try setting to another path. To do so, open the .cshrc file in a text editor, and edit the value of the PATH variable. It is also possible to set it manually at the UNIX prompt for the duration of a given command window by typing:
set PATH = ( value_of_variable )
Article ID:000005251
Software:
  • Legacy Products
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
