ERROR
MSEEK: Invalid Argument while accessing file (seeking to position -2147483648 of ...
Last Published: April 26, 2020
Error Message
Grid operations display the following error message:
Error:
"FATAL ERROR
MSEEK: Invalid Argument while accessing file (seeking to position -2147483648 of -2147483648 for read):
/path/to/grid/w001001.adf
Bailing out of GRID
FATAL ERROR
Unable to re-open output file (P23RCV)"
Cause
The grid's w001001.adf file has exceeded the maximum file size allowed by 32 bit software applications of 2.147GB (2exp31 - 1).
Solution or Workaround
  • Process the data in several smaller pieces.
    Use AML reserved Grid variables to set the analysis window to a subsection of the original grid's extent. For example:
    Code:
    &DESCRIBE ingrd
    SETWINDOW %GRD$XMIN% %GRD$YMIN% ~
    	[CALC %GRD$XMIN% + ( ( %GRD$NCOLS% / 2 ) * %GRD$DX% )] ~
    	[CALC %GRD$YMIN% + ( ( %GRD$NROWS% / 2 ) * %GRD$DY% )]
    lowerleft = ingrd
    This SETWINDOW syntax sets the analysis window to the lower left quadrant of INGRD. With this window set, the LOWERLEFT grid is created directly from the INGRD cells in that window.
  • Reduce the resolution of the data. Use the Grid commands SETCELL or RESAMPLE.
Article ID:000002037
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
