HOW TO
Move the st_spatial_index between tablespaces in Oracle
Summary
Instructions provided describe how to move an st_geometry attribute's spatial index to a new tablespace. Reasons that may force the movement of a spatial index to a new tablespace could be space management or resource contention between multiple segments on the same physical disk.
To move a spatial index between tablespaces, use the Oracle ALTER TABLE command in SQL*Plus.
Procedure
The following example demonstrates how to move a table's spatial index to a new tablespace using the Oracle ALTER TABLE command in SQL*Plus.
The example's objective is to move the street table's spatial index from its current tablespace to a new tablespace named strt_idx_tbs.
  1. The first step is to identify the street table's unique geometry identifier. The geom_id is used as the unique identifier for the geometry and its spatial index's table name.
    Code:
    SQL> SELECT geom_id
    2 FROM sde.st_geometry_columns
    3 WHERE table_name = 'STREET'
    4 AND owner = USER;
    GEOM_ID
    102
  2. Next, execute the ALTER TABLE command to move the spatial index table to its new tablespace strt_idx_tbs. The name of the spatial index table to move is the combination of S<geom_id>_IDX$. After performing the move operation, a view can be queried to verify the table now exists in the new tablespace.
    Code:
    SQL> ALTER TABLE s102_idx$ MOVE TABLESPACE strt_idx_tbs;
    Table altered.
    SQL> SELECT tablespace_name
    2 FROM user_indexes
    3 WHERE index_name = 'S102$_IX1';
    TABLESPACE_NAME
    STRT_IDX_TBS
Article ID: 000009505
Software:
  • Legacy Products
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
