PROBLEM
In ModelBuilder, Remove Join errors out with "ERROR: 000229: Cannot open "file name" Failed to execute (Remove Join)"
First Published: January 26, 2018
It is sometimes necessary to create a temporary join in ModelBuilder, and later remove the join from the model. However, when using the Join Field tool to join the field, and using the Remove Join tool to remove the join, the process fails, and the following error is returned:
Cause
This is because the Join Field tool creates a permanent join, and therefore the Remove Join action does not remove the join and errors out.
The Remove Join can only remove joins that were created "in memory", such as by the Add Join tool.
Solution or Workaround
When creating a temporary join in ModelBuilder, use the Add Join tool to create a join that can later be removed using Remove Join tool.
Article ID: 000016764
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
