ERROR
When publishing an ArcGIS Mobile project using ArcGIS Server with Mobile Data Access checked, the following error is returned:
"ArcGIS Server:
Configuration <name>.MapServer can not be started.
Server Object instance creation failed on machine <servername>."
Also, the following error is logged in the server log files:
"MobileServer requires a custom extent to be set. The default extent is not acceptable (union of all layers)."
Custom extents are required by ArcGIS Mobile 10.
Article ID: 000010965
Get help from ArcGIS experts
Download the Esri Support App
