PROBLEM
After installing the ESRI License Manager and rebooting, the system displays a message that the hardware key is missing, not plugged in, or cannot be found.
The parallel port has not been enabled. Windows allows a printer to work even though the parallel port is not enabled.
Warning: The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary. Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
1. Browse to C:\Program Files\Rainbow Technologies\Sentinel System Driver and launch SetupSysDriver.exe.
2. Click Configure Driver and verify a physical address and port type for the parallel port.
Note: If these are not seen, the parallel port is not enabled. Continue with the steps below and enable it.3. Uninstall the Sentinel System Driver by clicking Start > Settings > Control Panel > Add/Remove Programs.
Article ID: 000005637
Get help from ArcGIS experts
Start chatting now
