PROBLEM
Missing ESRI XMI exporter tool in Visio 2003 Professional after installing
The ESRI XMI exporter tool is missing from Visio 2003 Professional after installing.
Cause
This is a known issue.
Solution or Workaround
  1. Start Visio 2003 professional.
  2. Set the macro security level to 'Low. This is located under Tools > Options > Security Tab > Macro Security button.
  3. Exit Visio.
  4. Follow the Visio 2003 professional installation procedure.
    <a href='https://support.esri.com/en/knowledgebase/techarticles/detail/26105' target='_blank'>How To: Install the Visio 2003 Professional UML to XMI Export Facility</a>
  5. Start Visio 2003 and navigate to the ESRI XMI exporter menu option.
Article ID: 000007574
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
