PROBLEM
Unable to set the resampling method because the Display tab for the image catalog layer properties dialog does not show up in ArcScene.
This is a known issue with ArcGIS 8.1.
If you have not installed Service Pack 1, you can set the Display tab properties in ArcMap, save the layer, and use the saved layer in ArcScene.
Get help from ArcGIS experts
Download the Esri Support App
