ERROR
If the 'CustomFormat_Client' page in the 'Common_Maptips' sample is run, it works as expected (assuming that the USA_Data sample data is being used). If modifying or customizing the maptips in a custom application or in a Web Mapping Application created using the default template, then running the Web Mapping Application after the layers have been set for the MapTips control, the following JavaScript error may be returned:
"Microsoft JScript runtime error: 'null' is null or not an object". ![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000010499/00N39000003LL24-0EM39000000wdAU.png)
This error is returned if the layer for which the MapTips content has been customized is not displayed on page load.
Causes could be that the layer for which the maptips were customized has been unchecked; or scale dependencies may be set, which is causing the layer to not be displayed on page load.
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000010499/00N39000003LL2C-0EM39000000wdAh.png)
Article ID: 000010499
Get help from ArcGIS experts
Start chatting now
