ERROR
When attempting to assign a ProjCoordSys object to the CoordinateSystem property of a Map or MapLayer object, the following error may occur:
Method 'CoordinateSystem' of object '_DMap' failed.
This error may occur if the ProjCoordSys object's Type property has been set equal to the Type property of another ProjCoordSys object. For example, code like this sometimes raises the error:
Dim mapPCS As New MapObjects2.ProjCoordSys
mapPCS.Type = Map1.Layers(0).CoordinateSystem.Type
Map1.CoordinateSystem = mapPCS
Don't pass the Type property. Set the new ProjCoordSys object equal to the layer's ProjCoordSys explicitly. For example,
Code:
Set mapPCS = Map1.Layers(0).CoordinateSystem
Set Map1.CoordinateSystem = mapPCS
Article ID:000002141
Get help from ArcGIS experts
Download the Esri Support App
