PROBLEM
Maps do not print to scale when printing from data view
First Published: May 5, 2016
Map does not print to scale when printing from data view. For example, a line that is 5000' long and the map scale is set to 1" = 1000', when measured on the printout, does not measure 5".
Cause
This is a known limitation of printing from the data view. The size of the data frame adjusts to fit the constraints of the page and may adjust the map scale. The difference in scale is proportionate to the size of the page selected.
Solution or Workaround
Print from layout view.
    Article ID: 000011084
    Software:
    • ArcMap
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
