PROBLEM
Some users may run into an issue where, when opening and using Map Viewer or applications that use the ArcGIS API for JavaScript 4.x., they notice that the machine's CPU usage (in Windows Task Manager, for example) spikes to 100%.
It may be necessary to enable the Use hardware acceleration when available setting in Google Chrome. Make sure that any work is saved before enabling this and relaunching, as follows:
Article ID: 000028546
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
