PROBLEM
When a project has a Location Architect model that includes a location definition identifier (LDI), users can add the LDI attribute to a map-enabled report to automatically display it on the map. For example, if the model has an LDI for 'Customer' associated with X,Y coordinates, and the Customer attribute is added to a map-enabled report, customer locations are displayed on the map as an X,Y layer.
However, sometimes when an LDI is added to the report, the map does not load. Instead, a spinner appears on the screen and remains active in place of the map. ![[O-Image] Spinner on map in report](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000013284/00N39000003LL24-0EM39000000wefB.png)
This problem may occur if the user creating the report does not have the Web Professional permission called 'Web modify the list of report objects'.
![[O-Image] Permission](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000013284/00N39000003LL2C-0EM39000000wefC.png)
Article ID: 000013284
Get help from ArcGIS experts
Start chatting now
