HOW TO
If a certificate is revoked, expired, or formatted improperly, it may prevent access on HTTPS on port 6443. If access on port 6080 is disabled or redirects to HTTPS, it may be impossible to update the SSL certificate on ArcGIS Server to regain access to the web pages.
There are two files that must be edited to do this.
In both these files, replace existing values with the value 'selfsignedcertificate', as follows:
Example of the corrected <machine name>.json file:
{"machineName":"<Machine FQDN>","platform":"<Platform Information>","ports":{"HTTP":6080,"webSocketsPort":6180,"HTTPS":6443},"ServerStartTime":1569011713367,"webServerMaxHeapSize":-1,"socMaxHeapSize":64,"webServerSSLEnabled":true,"webServerCertificateAlias":"selfsignedcertificate","adminURL":"https://<Machine FQDN>:6443/arcgis/admin","configuredState":"STARTED","synchronize":false,"underMaintenance":false}
Example of the corrected server.xml file:
<Connector SSLEnabled="true" URIEncoding="ISO-8859-1" ciphers="<SSL Ciphers>" clientAuth="false" connectionTimeout="20000" connectionUploadTimeout="10000000" disableUploadTimeout="false" keyAlias="selfsignedcertificate" keystoreFile="C:\Program Files\ArcGIS\Server\framework\etc\certificates\arcgis.keystore" keystorePass="<Keystore Password>" maxHttpHeaderSize="65535" maxPostSize="10485760" maxThreads="150" port="6443" protocol="org.apache.coyote.http11.Http11NioProtocol" relaxedQueryChars="" scheme="https" secure="true" server=" " sslEnabledProtocols="TLSv1.2" sslProtocol="TLS" useServerCipherSuitesOrder="true"/>
Article ID: 000021911
Get help from ArcGIS experts
Start chatting now
