PROBLEM
Lost edit operation prior to executing IVersionEdit:Reconcile
First Published: May 5, 2016
While programmatically performing edits on a versioned object class, the changes applied prior to calling IVersionEdit: Reconcile disappear or are lost.
Cause
The IVersionEdit:Reconcile method starts by aborting any active edit operations prior to starting the reconcile process. This verifies the version is in a consistent state before reconciling the version with the target version.
Solution or Workaround
Prior to calling IVersionEdit:Reconcile make sure the previous edit operation is stopped before continuing.
    Article ID: 000006765
    Software:
    • ArcMap
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
