PROBLEM
Login prompt appears on trying to access Portal content
First Published: August 14, 2025
Last Published: August 14, 2025
When trying to access any item in the Portal for ArcGIS content, a prompt to login using the ArcGIS Portal appears, without which accessing the content is not possible.
Cause
The browser was using stale or invalid session cookies, tokens, or a cached redirect.
Solution or Workaround
Any of the steps below should individually open the ArcGIS Portal item without the login prompt.
  • In an incognito/private browser, navigate to the ArcGIS Portal content page and try accessing any item.
  • In the browser settings, clear the browser cache.
  • Access the ArcGIS Portal content using a different browser.
Article ID: 000036695
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
